Beamex calibrators are precision instruments used for calibrating and testing a variety of process measurement and control devices. If there is a problem with the calibrator, it may display an error code to help identify the issue. Here are some common error codes that may be displayed by a Beamex calibrator and some potential solutions:
- Error Code 1: “Sensor error” - This error code indicates that there is a problem with the sensor in the calibrator. This could be caused by a problem with the sensor itself or with the way it is being used. To resolve this issue, try checking the sensor and its connections, and make sure that it is being used according to the manufacturer’s instructions.
- Error Code 2: “Communication error” - This error code indicates that there is a problem with the communication between the calibrator and the device being calibrated. This could be caused by a problem with the communication cable, the configuration of the calibrator, or the device itself. To resolve this issue, try checking the communication cable and its connections, verifying the configuration of the calibrator and the device, and making sure that both are turned on and functioning properly.
- Error Code 3: “Calibration error” - This error code indicates that there is a problem with the calibration process. This could be caused by a problem with the calibrator or with the device being calibrated. To resolve this issue, try checking the calibrator and its connections, and verifying that it is being used according to the manufacturer’s instructions. If the problem persists, contact the manufacturer for further assistance.
- Error Code 4: “Hardware error” - This error code indicates that there is a problem with the hardware in the calibrator. This could be caused by a malfunctioning component or a problem with the calibrator itself. To resolve this issue, try checking the calibrator and its connections, and make sure that it is being used according to the manufacturer’s instructions. If the problem persists, contact the manufacturer for further assistance.
