Are there any wireless sensors to detect vibrations in an object?
Yes, there are several wireless vibration sensors specifically designed for detecting vibrations in industrial machinery and equipment. These sensors are commonly used in predictive maintenance and condition monitoring programs, as they allow for remote, real-time tracking of machine health without the need for wiring, making installation easier and more flexible. Here are some popular options and their key features:
- Fluke 3561 FC Vibration Sensor
- Features: Wireless vibration monitoring with real-time data access through the Fluke Connect mobile app. It measures key vibration parameters like acceleration, velocity, and displacement.
- Range: Monitors in three axes and alerts for sudden changes.
- Applications: Ideal for smaller rotating equipment like motors, pumps, and fans.
- SKF Wireless Machine Condition Sensor
- Features: Measures temperature and vibration to track machine health continuously. It offers configurable alarm thresholds and connects wirelessly to gateways for data collection.
- Range: Long-range data transmission, making it suitable for complex setups.
- Applications: Suitable for both small and large machinery and can be used across different industries.
- Honeywell Versatilis™ Wireless Vibration Sensor
- Features: This compact sensor monitors vibration and temperature, connecting to Honeywell’s control systems and cloud platforms for remote monitoring and analysis.
- Range: High-range, allowing for monitoring in hazardous or hard-to-access locations.
- Applications: Often used in oil and gas, manufacturing, and heavy industries where predictive maintenance is critical.
- ABB Ability™ Smart Sensor for Motors
- Features: Monitors vibrations, temperature, and other parameters for electric motors. It connects to a mobile app or cloud service for remote insights and predictive maintenance.
- Range: Uses Bluetooth and supports long-range communication.
- Applications: Excellent for motor-driven equipment across manufacturing and processing plants.
- Bosch CISS (Connected Industrial Sensor Solution)
- Features: A multi-sensor device that includes vibration monitoring among other parameters (temperature, humidity, light, etc.). Data can be transmitted over Bluetooth.
- Range: Suitable for short- to mid-range monitoring.
- Applications: Works well for research, development, and industrial IoT (IIoT) applications, especially where multi-parameter data is needed.
- Analog Devices ADXL357 and ADXL362 Wireless Vibration Sensors
- Features: These wireless sensors have ultra-low noise and high resolution, perfect for detecting fine vibrations and shock events. They are often paired with custom wireless transmitters.
- Range: Depends on the selected wireless module but is generally suitable for close-to-mid-range monitoring.
- Applications: Ideal for laboratory setups, asset tracking, and early fault detection in smaller equipment.
These wireless vibration sensors are typically battery-powered and use protocols like Bluetooth, Wi-Fi, or proprietary mesh networks to transmit data to gateways or cloud services for remote access. This flexibility makes them a great option for keeping track of critical assets without the complexity of wired installations.
