There are different PLC networks used to connect devices to an Allen Bradley system, Data Highways and Control Net. Data highways are DH, DH+, DH 485.
DH:
DH is a local area network
Maximum number of devices can be connected: 64
DH link implements peer-to-peer communication through a scheme called floating master to provide each node equal access to become the master
A DH transmit 57.6K bits of data per second.
DH+ :
DH+ link is similar to the DH link, the only difference is that in the number of nodes, where the maximum number of allowed nodes are 15.
Maximum number of allowable devices are 64
Speed of data transmit ranges from 57.6, 115.2, or 230.4K bits per second.
DH+ is also implemented a peer-to-peer communication
DH485:
DH485 is a peer-to-peer programming data acquisition link with 32nodes.
Here peer-to-peer communication uses a token-passing scheme to rotate link master among the nodes.
DH 485 Network using AIC+
Control Net:
The ControlNet network provides high-speed transmission of time-critical I/O and interlocking data and messaging data.
This data transfer capability enhances I/O performance and peer-to-peer communication in any system or application
The ControlNet network is highly deterministic and repeatable and remains unaffected as devices are connected or disconnected from it.
