Air Curtains – The Unsung Hero of Energy Efficiency in Commercial Spaces
Hey everyone,
I wanted to share something that repeatedly gets overlooked in building efficiency discussions — air curtains. I had worked around HVAC and facility management for a while and I’m surprised by seeing how underrated these devices still are.
So, what exactly is an air curtain? An air curtain is a device placed above a doorway that blows a continuous stream of air over the opening. This invisible barrier separates two environments — keeping conditioned air inside and outside air, dust, insects, and pollutants out — without the need for a physical door.
Why should you care?
  • Energy savings – Open doors in commercial spaces can count for a major portion of heating/cooling loss. Air curtains can reduce that energy loss by up to 80% in some cases.
  • Improved comfort – No more cold drafts hitting customers or staff every time a door opens in winter.
  • Hygiene & pest control – Especially valuable in restaurants, food processing units, and hospitals where insects and airborne contaminants become a real problem.
  • Better customer experience – Retail stores and supermarkets use them to keep entrances open and inviting without compromising any internal temperature.
Where are they Mostly Used In Today’s Time?
  • Supermarkets & retail stores
  • Restaurants & commercial kitchens
  • Warehouses & cold storage facilities
  • Hospitals & clean rooms
  • Industrial manufacturing units
Some Points Which You Should Consider Before Buying One:
  1. Door width & height – The air curtain must cover the full width of the opening to be effective.
  2. Air velocity – Too low and it won’t seal; too high and it becomes disruptive or noisy.
  3. Heated vs. unheated – In colder climates, a heated air curtain makes more sense to avoid blowing cold air on people.
  4. Mounting height – The higher the door, the more powerful the unit needs to be.
My Point Of View: If you manage a commercial or industrial space with high foot traffic and frequent door openings, an air curtain is one of the smartest low-maintenance investments you can make. The ROI through energy savings alone often pays back the cost within 1–2 years.
Curious to know — has anyone here installed air curtains in their facility? What brand or type worked best for you? Please help me with this.
