The LVDT has distinct advantages over other devices used as a transducer for mechanical positions. Some of these advantages are :
Linearity of LVDT: Absolute linearity is defined as the largest deviation (or error) voltage of transducer output from the theoretical ideal, measured between zero and full-scale displacement and expressed as a percent of the full-scale output.
LVDT Sensitivity: In high-frequency excitation, the LVDT sensitivity is practically independent of changes in ambient temperature. Therefore, the sensitivity ratings are measured at a constant voltage, and are expressed as millivolts of output per volts of excitation per unit displacement (usually 0.01 mm) (mV / V / 0.01 mm).
In absence of any mechanical contact between the primary and secondary windings and the armature, there is no friction or hysteresis.
There is no mechanical wear and tear ensuring virtually infinite life.
Linear output assures accurate measurement with direct indicating instruments.
The resolution is very high, limited only by the indicating and control equipment.
The electrical output is completely isolated from the input, allowing addition or subtraction of signals without buffer amplifiers.
High-level output simplifies electronic circuitry.
Over-ranging does not cause any damage or permanent change in characteristics.
The LVDT is rugged and shock-resistant, and virtually maintenance-free.
