Turbine meter is a good flow measuring unit when the fluid is low clean fluid. The turbine meter measures the volumetric flow. It is directly installed on the flow line. Its accuracy in flow measurement is high. Accuracy can be re-calculated and the ‘k’ factor can be reset periodically
