Power transformer failures can result from insulation degradation, winding faults, overloading, overheating, moisture ingress, oil deterioration, and inadequate maintenance. Identifying these failure mechanisms through routine inspections and diagnostic testing helps improve transformer reliability and operational safety.
Major Causes and Corrective Measures:
- Insulation Deterioration: Perform insulation resistance, polarization index, and dielectric diagnostic tests. Investigate moisture ingress and thermal ageing.
- Winding Faults: Conduct winding resistance, transformer turns ratio (TTR), and short-circuit impedance tests to identify inter-turn faults, open circuits, and winding deformation.
- Transformer Overloading: Monitor load current, temperature, and loading profile. Ensure loading remains within the transformer’s rated capacity.
- Overheating: Inspect the cooling system, radiators, fans, oil pumps, and temperature indicators. Verify proper heat dissipation.
- Transformer Oil Deterioration: Perform oil BDV, moisture content, acidity, and dissolved gas analysis (DGA) tests. Filter, dehydrate, or replace oil when required.
- Lightning and Switching Surges: Inspect surge arresters, verify protective coordination, and check the effectiveness of the transformer earthing system.
- Poor Maintenance and Loose Connections: Conduct periodic inspections, thermographic surveys, contact resistance measurements, and preventive maintenance.
Proper condition monitoring, protection system testing, and preventive maintenance help minimize unexpected transformer failures and extend equipment service life.
