1. HMI Modbus TCP Bluetooth
This app can be considered as a replacement for the HMI operator panel. This app has certain functions of SCADA systems such as reading and writing of different data types. This app supports Modbus TCP/IP. In order to use Modbus RTU/ASC additional Modbus converter is required. This app is capable to do communicating through Bluetooth for Arduino and other devices. This app read, write functions support int16, int32, float, float swap, and Boolean data types.
Download link
2. Virtuino Modbus
This app is an HMI platform that can be used to create amazing visual screens on our device and it can also control or monitor the automation system through Modbus TCP/IP protocol.
Download link
https://play.google.com/store/apps/details?id=com.virtuino.virtuino_modbus
3. Virtual HMI
This app can change our android device into a virtual HMI and without any cost. By using this app we can control and read useful information from PLC.
Download link
4. Suppanel HMI
By using this app we can create and visualize supervisory panels type HMI/SCADA on the same device. This device would help us to connect to a wide range of PLC or other equipment through
- OPC UA server
- Ethernet/IP
- Modbus TCP
- Ethernet/IP with micrologix and SLC 500 controllers
We can instantly switch from design to run mode and vice-versa for quick debugging. This app will be very useful for home automation and industrial automation. This app has some example panels by which we can practice.
Download link
5. MobileHMI
With the help of this app, we can access and control enterprise industrial automation applications from anywhere. This app displays application assets, alarms, and trends. This application allows the user to be informed from any-where, this app will let us control the operation remotely and also can view the operational condition in real-time
Download link
6. HMI Modbus viewer
This app is mostly designed for the execution of the project that is created in the HMI Modbus https://play.google.com/store/apps/details?id=net.sagram.hmi_modbus
So before opening this app we must export the project to any external folder using HMI Modbus.
Download link
7. HMI-KaScada Modbus
By using this app we can convert our android device into a control panel and this app also allows us to create projects. It also allows visualizations for devices that support the MODBUS RTU protocol using control buttons, switches, presets, and indicators –lamps, digital and analog presets. Mini SCADA will allow us to display graphics, pictures, animation, archive data, and also can send archives to email and cloud storage.
Download link
