1. Every circuit
This app would help us to know about electrical circuits and how they work, users can interact with this app very easily. By using this app we can build any circuit and run it after that we can see the dynamic voltage, charge, and current animations. This app would give better circuit insight, we can adjust the parameter of the circuit with the analog knob and the circuit would react to it very quickly. We could even generate an arbitrary input signal with our finger. With the help of the components in this app, we can design any analog and digital circuits. This app would be helpful for students, and teachers. This app contains many components like DC motor, potentiometer, logic gates, counter, and lot more.
Download link
2.Electronic lab - toolbox kit EE
The electronic lab is a great app for students and electrical engineers. By using this app we can design a power circuit, program an Arduino board, or even analyze an electronic signal on the go. We can use many bulky tools of the electronics and electrical industry. The app consists of electronic codes, calculators, formulas, unit conversion, and a lot more. By using this app we can do the circuit design and simulation, it can be used to design a PCB and also to do the chip simulation.
Download link
3.EC studio
This app can be used to create electronic circuits, SPICE simulation, and calculation of circuit. This app consists of many resources such as connector pin-outs and it also has certain books that describe electronics laws and theorems. We can easily create an electronic circuit by this app and also will do the SPICE analysis. We can also see the visual representation of the simulated results, as the simulated voltages and currents, can be placed anywhere in the circuit, as a text or graph.
Other features of this app
- It supports DC, AC, and transient analysis
- Logic gates and transistors
- DC voltage and current source
- Electronic calculators and lot more
Download link
4.Droid tesla demo
This is a simple and effective circuit simulator, it is very useful for students, with the help of this app we can do the electronic circuit design and calculation. For a nonlinear component such as the diode and the BJT, this app searches for the approximate solution by making an initial guess at an answer and this will improve the solution with successive calculations and this is the interactive process of this app. There are many components in this app that would help us to design complex circuits.
Download link
5. Simple circuit builder, series-parallel resistors
This app can be considered as a virtual breadboard of pre-configured resistors. This app is meant for beginners. By using this app we can create basic electronic circuits. It also has virtual volt and amp meters. By using this app we could learn how to measure voltages across resistors, and also current through series and parallel circuits. The component values can be easily changed in this app.
Download link
6. Smart logic simulator
By using this app we can create circuits by using logic gates and flip flops, we can see a variety of different input and output in this app. In this app, we can also see different kinds of sensors like proximity sensor, light sensor, and much more. We can easily design a circuit with this app by its intuitive interface.
Download link
7. Circuitree: Electronic circuit tools
By using this app we can consult formulas and information that will help us to understand how it works. We can insert the component values of the circuit and the app will compute it in real-time and also with time graphs and bode plots. It has a tool called auto design tool which would allow us to find all the combinations of standard values that result in the value we want.
Download link
