[url= Transformer Oil Dehydration Working Procedure][color=#1E00A3] Transformer [/color][/url] failures are typically ignored because they communicate through weak indicators.
Ignoring these early signs might cause unanticipated outages, equipment damage, & costly repairs.
Here are 6 common indoor transformer faults and their potential interpretations:
[color=#ff0000]6 Common Faults found in Indoor Transformers [/color]
- Insulation Breakdown
- Core Earthing Failure
- Overloading
- Overheating
- Partial Discharges (PD)
- Oil Leaks
[color=#ff0000]1). Insulation Breakdown [/color]
Symptom: Flashovers, low insulation resistance (IR) values
Risk: Electrical faults & insulation collapse
Solution: Schedule regular insulation resistance & tan delta tests to detect early insulation degradation.
[color=#ff0000]2). Core Earthing Failure [/color]
Symptom: Unexplained (or) unexpected differential relay trips
Risk: Induced voltages & potential internal arcing
Solution: Inspect & ensure core earthing continuity at routine shutdowns.
[color=#ff0000]3). Overloading [/color]
Symptom: Overheating, frequent tripping at peak hours
Risk: Accelerated insulation aging & thermal stress
Solution: Monitor load in kVA, review loading patterns, & balance phases to prevent overload.
[color=#ff0000]4). Overheating [/color]
Symptom: High temperature alarms, and rapid oil degradation
Risk: Insulation damage & reduced transformer life
Solution: Clean radiator fins, check fan operation, & test oil temperature relays for the proper function.
[color=#ff0000]5). Partial Discharges (PD) [/color]
Symptom: Audible hissing sounds, corona marks on the insulation
Risk: Localized dielectric breakdown & eventual flashover
Solution: Use PD detection tools & visually inspect bushings & insulation systems.
[color=#ff0000]6). Oil Leaks [/color]
Symptom: Visible oil stains, low oil level indicators
Risk: Loss of insulation & cooling capacity
Solution: Tighten fittings, replace damaged gaskets, & inspect conservator and breather systems.
Transformer failure is best prevented by early identification and maintenance.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
