What is SF6 and why is it utilized in Circuit Breakers?
Sulfur hexafluoride, or SF6, is an essential gas in high-voltage circuit breakers, switchgear, & other electrical equipment.
It works as both
  • An insulator &
  • An arc-quenching medium,
ensuring that electrical currents are interrupted safely and efficiently.
SF6 gas is used in circuit breakers to insulate & extinguishing arcs that occur when the breaker contacts separate under high voltage.
Its unique features, including as non-flammability, chemical stability, and good electrical insulation, make it a perfect medium for this application.
Furthermore, SF6 allows circuit breakers to function at higher voltages and interrupt higher fault currents than alternatives.
Despite its effectiveness, SF6 is a major environmental concern due to its thousands of times larger global warming potential than CO2.
As a result, there is a rising movement to reduce SF6 usage in electrical equipment and explore environmentally friendly replacements.
