What is a Voltage Sensor? Types, Working Principle and Applications
What Is a Voltage Sensor? Types, Working Principle, and Applications
A voltage sensor is an electrical measurement device used to detect, monitor, and measure voltage levels in AC and DC circuits. It converts the measured voltage into a proportional electrical signal for monitoring, control, or protection systems.
Working Principle of a Voltage Sensor
Voltage sensors operate using voltage dividers, resistive networks, transformers, or Hall-effect technology, depending on the sensor type. They are widely used in PLC systems, power supplies, battery management systems, solar inverters, and industrial automation.
Types and Applications of Voltage Sensors
Common types include AC voltage sensors, DC voltage sensors, isolated voltage transducers, and non-contact voltage detectors. Selecting the correct sensor requires considering the input voltage range, measurement accuracy, isolation rating, and output signal.
Voltage sensors improve electrical system monitoring, fault detection, and equipment safety.
