# Basic Smoke Detection devices
**URL:** <https://forumautomation.com/t/basic-smoke-detection-devices/4114>\
**Category:** Fire and gas\
**Created:** [July 16, 2018, 4:36am UTC](https://forumautomation.com/t/basic-smoke-detection-devices/4114 "2018-07-16T04:36:08Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![areejsidhik](https://forumautomation.com/letter_avatar_proxy/v4/letter/a/ee59a6/32.png) [@areejsidhik](https://forumautomation.com/u/areejsidhik)\
**Post date:** [July 16, 2018, 4:36am UTC](https://forumautomation.com/t/basic-smoke-detection-devices/4114/1 "2018-07-16T04:36:08Z")
</div>
Smoke detection technology ranges from the battery-powered detectors on sale generally to sophisticated visual, camera-based detection systems.
> ## Point Smoke Detectors
Point detectors detect smoke at a fixed point. They need to be placed where smoke realistically could travel in the event of a fire. The majority in use rely on smoke accessing a chamber containing the detector element. These detectors therefore have a low IP rating and cannot be used in external areas. With the use of addressable systems, each location can be pinpointed.
![1](https://cdn.forumautomation.com/original/2X/0/01c0d9cc2c03205161f9797cc04e2341a95b389d.jpg)
> ## Ionisation Point Smoke Detectors
This used to be the predominant smoke detection technology. It has been largely superseded by optical or combined optical smoke /heat detectors. These detectors use a small radioactive source and detect decreased conduction caused by the ionisation of smoke particles in a detection chamber. For this reason they are susceptible to alarming in areas of high humidity.
 ![1](https://cdn.forumautomation.com/original/2X/4/41d2fbe3365d709a79a7f62b2efc646a73d5f638.jpg)
> ## Optical Point Smoke Detectors
These detectors generally detect smoke particles inside a chamber by an increase of light scatter caused by smoke particles or by the smoke particles obscuring a light beam. ![1](https://cdn.forumautomation.com/original/2X/0/0bb32e3f9934c47dbd494e701fc42a698dedefc6.jpg)
> ## Combined Optical Smoke/Heat Point Detectors
Uses a heat sensor to sense a rapidly rising temperature caused by a high energy fire. sensor combines optical smoke sensing and thermal monitoring to provide an accurate warning of fire. Individual software monitoring of each element measures actual smoke levels .Multi-sensor fire detector incorporates two sensors, one for smoke and one for heat. As well as operating independently, the signals from the two sensors combine to produce a more sensitive response to freely burning fires. For example, when the detector’s heat sensor detects an increase in temperature, it reduces the level at which its smoke sensor will respond. ![1](https://cdn.forumautomation.com/original/2X/b/b346ff18646483c5239838ea891311a1b37689e0.jpg)
> ## Laser Point Smoke detector
Laser point detectors offer increased sensitivity over general purpose optical point smoke detectors at the expense of increased cost per location. They use the same principles as the optical point smoke detectors. ![1](https://cdn.forumautomation.com/original/2X/9/9efed26dc745f4dc8d22d3db0870de3ba68d04f1.jpg)
> ## Beam Smoke Detectors
A beam of light is interrupted by smoke particles.monitoring of large areas e.g. atria, machinery spaces, areas where it is impractical or impossible to mount other detection types. ![1](https://cdn.forumautomation.com/original/2X/c/c15295b8cf0b091ff73bd16283c86524e41d2640.jpg)
> ## Aspiration Smoke Detectors
Established technology provides early warning of fires, often before smoke is visible. Provides area coverage by the use of sampling tubes and continuous detection for smoke particles drawn through the tubes into the detection unit. Requires power in field. Generally can only be used in a safe area. The normal configuration of one unit is a single point of failure. used in: Instrument rooms, telecommunications rooms, control rooms.
 ![1](https://cdn.forumautomation.com/original/2X/e/ef8c56b9f2b5c251939ce52ce1d255727b518ef5.jpg)
> ## Camera-based Smoke Detectors
Detectors that monitor the characteristic shape of smoke. Continuous light is essential for smoke detection. ![1](https://cdn.forumautomation.com/original/2X/7/75bbda8e20f90336b11ab7e89b184975e1c99907.jpg)
**Also read**** [Basic Fire Detection systems](https://forumautomation.com/t/basic-fire-detection-systems/4111/1)****[Applications of condensate pot](https://forumautomation.com/t/applications-of-condensate-pot/4055/1)**
