# Advantages of PLC
**URL:** <https://forumautomation.com/t/advantages-of-plc/3672>\
**Category:** PLC (Programmable Logic Controllers)\
**Created:** [May 22, 2018, 5:33pm UTC](https://forumautomation.com/t/advantages-of-plc/3672 "2018-05-22T17:33:01Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![sivaranjith](https://forumautomation.com/letter_avatar_proxy/v4/letter/s/ba9def/32.png) [@sivaranjith](https://forumautomation.com/u/sivaranjith)\
**Post date:** [May 22, 2018, 5:33pm UTC](https://forumautomation.com/t/advantages-of-plc/3672/1 "2018-05-22T17:33:01Z")
</div>
- PLC is basically designed to operate in an industrial environment with wide range s of ambient temperature and humidity
- All the capabilities of the earlier systems
- Hardware and software of the PLC are designed for easy use by the plant technician and electricians.
- The dramatic performance increase over the relay logic systems
- Troubleshooting is simpler with PLC’s as they have been provided with fault indicators and written fault information displayed on the screen.
- Greater reliability
- Little maintenance due to no moving parts
- No special programming skills required by maintenance personnel
- The physical size of the PLC system is much smaller than the conventional relay-based logic
- Lower cost
- Ease of programming
- Ease of maintenance
- Designed for industrial environment
- Quick installation
- Adaptable to change
- PLC’s are not affected by electrical noise problems
Also read **[Low Cost PLC’s for beginners](https://automationforum.co/2018/05/low-cost-plcs-beginners.html)**
